I’m facing difficulties when trying to downgrade a Komar ESC from telega version 1.0 to 0.6.
The Komar was bought in June 2022 and shipped with telega v0 firmware flashed.
The ESCs have been upgraded to telega v1, but after evaluation we decided to revert to v0 for our application.
I have a working slcan/yakut environment with the following nodes:
NodID Mode Health VSSC Uptime VProtcl VHardwr VSoftware(major.minor.vcs.crc) Unique-ID Name
10 oper nomina 6 0d00:20:05 1.0 0.0 0.13 7c1af0cd99ae1d104c5174bcd8bcdded org.opencyphal.yakut.file_server
88 oper nomina 46 0d00:37:41 1.0 0.0 0.13 674b81747fce75c6537666263aca99fe org.opencyphal.yakut.monitor
92 oper nomina 94 offline 1.0 0.0 0.13 9dc9e18c708492956166c5776658ae2b org.opencyphal.yakut.call
124 oper nomina 0 0d00:08:09 1.0 1.7 1.0.1e5c06b5751eefb2.6a34880f9af5cb71 25001e000c5030533135332000000000 com.zubax.telega
where 124 is the ESC I’m trying to downgrade, 10 is my fileserver serving the binary, 88 the monitor and 92 another terminal from which I call commands.
I followed these steps for the (unsuccessfull) downgrade to v0:
- download com.zubax.telega-1-0.6.cd758ab7.application.bin
- rename this file to
com.zubax.telega-200.0.app.binand move to folder named0_6 - start the firmware update procedure using
y --verbose file-server --plug-and-play allocation_table.db ./0_6 --update-software 124
which results in the following output:
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: File server root directories: ['<HIDDEN>/0_6']
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Total update: False; trigger explicitly: [124]
2024-11-09 21:15:19 0035856 INF yakut.param.transport: Transport constructed from registers: CANTransport(SocketCANMedia('slcan0', mtu=8), local_node_id=92)
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Starting a plug-and-play allocator using file '<HIDDEN>/allocation_table.db'
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Initializing the node tracker
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Initializing the software update checker
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Node 124 most recent heartbeat: uavcan.node.Heartbeat.1.0(uptime=29, health=uavcan.node.Health.1.0(value=0), mode=uavcan.node.Mode.1.0(value=0), vendor_specific_status_code=0)
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Node 124 info: <not available>
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Node 124 info: uavcan.node.GetInfo.Response.1.0(protocol_version=uavcan.node.Version.1.0(major=1, minor=0), hardware_version=uavcan.node.Version.1.0(major=1, minor=7), software_version=uavcan.node.Version.1.0(major=1, minor=0), software_vcs_revision_id=2187630895419027378, unique_id=[37, 0,30, 0,12,80,48,83,49,53,51,32, 0, 0, 0, 0], name='com.zubax.telega', software_image_crc=[7652891267415001969], certificate_of_authenticity='<\xb0\xe8_;\xd3\x0f\xbc\xf5e\xa3\xb4\xa4\x9f\x15\xfe\x1cO\xd5\x9a\x90\x8dEoLbQ!~f\xe1][7\x84\x8f\xbf\xe1o\xe5 q>\x85\xff\xd7\xc3\x9a\xc7F\x8c_:I\xbb/\x92\\l\xc0:9\x1b\xb1\xa7\x86g\xed\xc5\x7f\xf65\xff?\xd4\xf2g\xfc\x83\x9e\x8c\xf7(\x84\x08\xe2\x86b\xa5\xe5\x16\x86\x84\xeb!\x0f\xce\xd3#\x83\xe7\xe0\xcb\\hZ\xf6\xeb:S\xd8\xfd\xc7@\xfd\xe2\xff\xd1S\xcc\xe1?U\n^gF\xe28\x0b\xa5\x81\r\x9f\x1f\xdb& \x04sNi\x90*\xee\x80;\xaa{\x0b|\x07\xa0@\xdab\xc2\x03C\xc2\x16\xad\xab\xfcO\xc2\xce\xac>\xb7(E+jt\xbd7>ZEc[\x18\xf1/\rY\xc9A\x11\xa6\xc5\xc0\x05\x8fz\xf7\xdb\xa1Aa\x9c(_\xfdB\x84\xc2\xd8K\xd8\xaaq;\xe3{-\xa6\xdah\x0cV')
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Checking if node 124 requires a software update...
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: com.zubax.telega-1.7-1.0.1e5c06b5751eefb2.6a34880f9af5cb71.app: Checking if com.zubax.telega-200.0.app is equivalent...
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: com.zubax.telega-1.7-1.0.1e5c06b5751eefb2.6a34880f9af5cb71.app: No, the software version does not match.
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: com.zubax.telega-1.7-1.0.1e5c06b5751eefb2.6a34880f9af5cb71.app: Checking if this app should be updated to com.zubax.telega-200.0.app...
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: com.zubax.telega-1.7-1.0.1e5c06b5751eefb2.6a34880f9af5cb71.app: The applications appear to be compatible -- an update would not break the node. Looking further...
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: com.zubax.telega-1.7-1.0.1e5c06b5751eefb2.6a34880f9af5cb71.app: CRC is identical or not defined, checking the version information...
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: com.zubax.telega-1.7-1.0.1e5c06b5751eefb2.6a34880f9af5cb71.app: Yes, com.zubax.telega-200.0.app is of a different version and is not older than the current one.
2024-11-09 21:15:19 0035856 WAR yakut.cmd.file_server: Requesting node 124 to update its software: uavcan.node.ExecuteCommand.Request.1.1(command=65533, parameter='com.zubax.telega-200.0.app.bin')
2024-11-09 21:15:19 0035856 INF yakut.cmd.file_server: Node 124 confirmed software update command uavcan.node.ExecuteCommand.Request.1.1(command=65533, parameter='com.zubax.telega-200.0.app.bin')
2024-11-09 21:15:23 0035856 INF yakut.cmd.file_server: Node 124 went offline
[5 second delay]
2024-11-09 21:15:28 0035856 INF yakut.cmd.file_server: Node 124 most recent heartbeat: uavcan.node.Heartbeat.1.0(uptime=3, health=uavcan.node.Health.1.0(value=0), mode=uavcan.node.Mode.1.0(value=0), vendor_specific_status_code=0)
indicating that the ESC tried to do the firmware upgrade/downgrade but was not successful since it still runs v1.0.
I also discovered that this Komar ESC might suffer from the bootloader regression. Thus I tried following the instructions from the readme, adjusting the commands for the use with yakut and cyphal since DronecanGUI does not work with cyphal.
- run the solver
solver 1000000 124 10 > out.bin, which gives me65,9f,4e,64,eb,c7,98,30as a filename. - execute a software update command with this as a filename:
yakut call 124 435:uavcan.node.ExecuteCommand '{command: 65533, parameter: b"e\x9fNd\xeb\xc7\x980"}'
where b"e\x9fNd\xeb\xc7\x980" is deduced from bytes([0x65,0x9f,0x4e,0x64,0xeb,0xc7,0x98,0x30])
resulting in this output on the command terminal (node 92):
435: {status: 0, output: ''}
and this output on the file-server (node 10):
2024-11-09 21:25:14 0037121 INF yakut.cmd.file_server: Node 92 most recent heartbeat: uavcan.node.Heartbeat.1.0(uptime=0, health=uavcan.node.Health.1.0(value=0), mode=uavcan.node.Mode.1.0(value=0), vendor_specific_status_code=41)
2024-11-09 21:25:14 0037121 INF yakut.cmd.file_server: Node 92 info: <not available>
2024-11-09 21:25:17 0037121 INF yakut.cmd.file_server: Node 92 went offline
2024-11-09 21:25:18 0037121 INF yakut.cmd.file_server: Node 124 went offline
2024-11-09 21:25:23 0037121 INF yakut.cmd.file_server: Node 124 most recent heartbeat: uavcan.node.Heartbeat.1.0(uptime=3, health=uavcan.node.Health.1.0(value=0), mode=uavcan.node.Mode.1.0(value=0), vendor_specific_status_code=0)
2024-11-09 21:25:23 0037121 INF yakut.cmd.file_server: Node 124 info: <not available>
2024-11-09 21:25:23 0037121 INF yakut.cmd.file_server: Node 124 info: uavcan.node.GetInfo.Response.1.0(protocol_version=uavcan.node.Version.1.0(major=1, minor=0), hardware_version=uavcan.node.Version.1.0(major=1, minor=7), software_version=uavcan.node.Version.1.0(major=1, minor=0), software_vcs_revision_id=2187630895419027378, unique_id=[37, 0,30, 0,12,80,48,83,49,53,51,32, 0, 0, 0, 0], name='com.zubax.telega', software_image_crc=[7652891267415001969], certificate_of_authenticity='<\xb0\xe8_;\xd3\x0f\xbc\xf5e\xa3\xb4\xa4\x9f\x15\xfe\x1cO\xd5\x9a\x90\x8dEoLbQ!~f\xe1][7\x84\x8f\xbf\xe1o\xe5 q>\x85\xff\xd7\xc3\x9a\xc7F\x8c_:I\xbb/\x92\\l\xc0:9\x1b\xb1\xa7\x86g\xed\xc5\x7f\xf65\xff?\xd4\xf2g\xfc\x83\x9e\x8c\xf7(\x84\x08\xe2\x86b\xa5\xe5\x16\x86\x84\xeb!\x0f\xce\xd3#\x83\xe7\xe0\xcb\\hZ\xf6\xeb:S\xd8\xfd\xc7@\xfd\xe2\xff\xd1S\xcc\xe1?U\n^gF\xe28\x0b\xa5\x81\r\x9f\x1f\xdb& \x04sNi\x90*\xee\x80;\xaa{\x0b|\x07\xa0@\xdab\xc2\x03C\xc2\x16\xad\xab\xfcO\xc2\xce\xac>\xb7(E+jt\xbd7>ZEc[\x18\xf1/\rY\xc9A\x11\xa6\xc5\xc0\x05\x8fz\xf7\xdb\xa1Aa\x9c(_\xfdB\x84\xc2\xd8K\xd8\xaaq;\xe3{-\xa6\xdah\x0cV')
- try serving the otp-fix firmware from here:
using and requesting an update using
yakut call 124 435:uavcan.node.ExecuteCommand '{command: 65533, parameter: "com.zubax.telega.otpfixer-255.0.4b5f3dea16d148aa.3afd0d4ad2684d76.app.release.bin"}'
The node restart and comes back up, still with firmware v1.0.
What are the next steps? How can I downgrade my Komar ESCs to telega v0?
I also tried getting some debug information from the Mitochondrik LV by reading the output form it’s UART port. Only to find out that nothing seems to be transmitted there. Where can I find documentation of the UART functionality? The Mitochondrik LV datasheet notes the following: Refer to the Telega Reference Manual for information
regarding its functions and availability. Though I could not find any references to UART in the Telega v1 Reference Manual.
Thank you in advance!
Best wishes,
Sandro
P.S.: We also have some Myxa ESCs. And if I remember correctly, the switch between v0 and v1 went seamlessly in both directions for them.
