We are evaluating four AmpDrive AD0505D0Z ESCs for a quadrotor UAV powered by a 6S LiPo battery (22.2 V nominal), using four T-Motor MN4116 KV340 motors and a Cube Orange+ flight controller with DroneCAN.
Before powering and configuring the controllers, we would appreciate clarification on four points.
We have reviewed the Telega v0 quick-start guide, the AD0505C/D datasheet (rev. 2025-04-16), and previous discussions on your forum.
1. Firmware compatibility, migration and reliability
Is the standard Telega v0.6 release fully supported on the AD0505D0Z? Which official firmware image and build should be used?
If our units are supplied with Telega v1, should we use the application image or the compound image when migrating to v0.6, and which parameters must be configured or verified after the reset? In particular, should hardware-specific calibration values such as vsi.dc_voltage_gain be checked, and how can we verify that they are correct without overwriting factory calibration data?
We have also reviewed the reported unexpected shutdowns in forum topic 2785, “Myxa AD0505C0Z abrupt shutdown”.
We note your March 1 reply suggesting a possible hardware issue in one case, while the later AD0505D0 / Cube Orange+ / DroneCAN report has no public follow-up after March 25.
Has the cause of the latter issue been identified, and are any firmware revisions, diagnostic checks or configuration precautions recommended?
2. Stop behaviour and DroneCAN parameters
For the AD0505D0Z running standard Telega v0.6:
Does
ctl.hard_stopbehave as described in your your July 2020 forum discussion, topic 1631, “Questions after testing Myxa”, when a zero or near-zerouavcan.equipment.esc.RawCommandsetpoint is received? -
Does the same behaviour apply when
uavcan.esc_ttlexpires? -
What are the factory-default values of
uavcan.esc_ttlanduavcan.esc_rcm?
We understand that uavcan.esc_rcm selects current, RPM or voltage control (0, 1 or 2 respectively).
3. Motor identification
Does motor identification initiated by exec_aux_command = 1002 cause physical rotor movement?
In your your April 2018 Myxa guide, topic 911, “Quick start guide for Myxa”, you state that motors with poor parameter repeatability, including T-Motor, “always require identification for every motor”.
Does this guidance still apply to the MN4116 KV340 with AD0505D0Z and standard Telega v0.6, even when manually entered motor parameters are available?
4. Control-logic supply and emergency shutdown
According to sections 2.2.1 and 2.3 of the AD0505C/D datasheet, the controller does not draw power from CAN, and the BEC outputs are protected against reverse powering.
Is there any manufacturer-supported method to power and configure only the control logic without energizing the main DC-link?
If not, is it supported to configure one ESC at a time from a current-limited DC power supply, with all three motor phase leads disconnected, strictly for parameter configuration and without motor identification?
Finally, considering the regenerative braking behaviour and overvoltage precautions described in section 2.1.2 of the datasheet, what emergency shutdown sequence and physical power-isolation arrangement do you recommend for bench testing with the motor connected?
In particular, how should a hazardous fault be handled if the motor is still rotating and immediate disconnection of the DC supply is being considered?
We understand that suitable regenerative-energy absorption is required; our question concerns the recommended shutdown and isolation sequence rather than the general use of an electronic load or additional capacitance.
Thank you for your assistance.
