Hello How could we flash the stm32 inside the sapog ESC?
the command ./blackmagic_flash.sh [portname] (/dev/ttyUSB0 in my case)
is not making any result
Please describe what debugger are you using? The command you mentioned only works with Dronecode Probe and Black Magic Probe adapters.
If you don’t have any of the above, you could use the embedded UAVCAN bootloader via the UAVCAN GUI Tool.
we tried to flash it with a simple FTTI adpater …
in our case we have a bare stm32 without any bootloader installed
Ah, sorry that won’t work, you need a debugger. I believe you can order a Dronecode Probe here nicadrone.com
Thanks Pavel.
Now with a Dronecode probe it is better, I am able to flash it.
However, after flashing I’m not able to configure it with the serial interface. Do I have to update the source code somewhere to activate this interface?
The serial interface is always enabled. Make sure the hardware is functioning, the firmware is running, and the serial port settings are correct. The latter are provided at page 29 here https://files.zubax.com/products/io.px4.sapog/Sapog_v2_Reference_Manual.pdf.
The hardware is an official orel 20 esc and was working before we flashed it.
what puzzles me is that in your hal definition file, neither CAN nor the UART are activated, is that normal?
#define HAL_USE_TM TRUE
#define HAL_USE_PAL TRUE
#define HAL_USE_ADC FALSE
#define HAL_USE_CAN FALSE
#define HAL_USE_DAC FALSE
#define HAL_USE_EXT FALSE
#define HAL_USE_GPT FALSE
#define HAL_USE_I2C FALSE
#define HAL_USE_I2S FALSE
#define HAL_USE_ICU TRUE
#define HAL_USE_MAC FALSE
#define HAL_USE_MMC_SPI FALSE
#define HAL_USE_PWM FALSE
#define HAL_USE_RTC FALSE
#define HAL_USE_SDC FALSE
#define HAL_USE_SERIAL TRUE
#define HAL_USE_SERIAL_USB FALSE
#define HAL_USE_SPI FALSE
#define HAL_USE_UART FALSE
#define HAL_USE_USB FALSE
#define HAL_USE_WDG FALSE
Yes. In ChibiOS parlance, what we’re using is called SERIAL, not UART. The latter is a lower-level driver. CAN is provided by Libuavcan, which doesn’t need the abstractions provided by ChibiOS - it works directly with the hardware.
then why doen’t it work, when we flash it manually? Did we forgot a step?
Please post here the full build output here after make clean, I’ll have a look. Also please submit the contents of your build directory after the build, and the output of the command that you use to flash the board.
build output
philippe@philippe-MS-7641:~/sapog/firmware$ make clean
Cleaning
rm -fR .dep build
Done
philippe@philippe-MS-7641:~/sapog/firmware$ make RELEASE=1
Compiler Options
arm-none-eabi-gcc -c -mcpu=cortex-m3 -falign-functions=16 -U__STRICT_ANSI__ -fno-exceptions -fno-unwind-tables -fno-stack-protector -fno-builtin-printf -fno-builtin-fprintf -fno-builtin-vprintf -fno-builtin-vfprintf -fno-builtin-puts -u_port_lock -u_port_unlock -u_exit -u_kill -u_getpid -uchThdExit -u__errno -nodefaultlibs -lc -lgcc -lm -O2 -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-common -flto -std=c99 -Wshadow -Wpointer-arith -Wno-packed -Wno-attributes -Wno-error=undef -Wno-error=shadow -Werror -Wall -Wextra -Wstrict-prototypes -Wa,-alms=build/lst/ -DCORTEX_VTOR_INIT=16384 -DCRT1_AREAS_NUMBER=0 -DCONFIG_PARAMS_MAX=50 -DRELEASE_BUILD=1 -DNDEBUG=1 -Dasm=__asm -DCORTEX_USE_FPU=FALSE -DFW_VERSION_MAJOR=2 -DFW_VERSION_MINOR=2 -DHW_VERSION_MAJOR=1 -DNODE_NAME="io.px4.sapog" -DCONFIG_PARAM_MAX_NAME_LENGTH=16 -DUAVCAN_STM32_TIMER_NUMBER=7 -DUAVCAN_STM32_NUM_IFACES=2 -DUAVCAN_CPP_VERSION=UAVCAN_CPP11 -DUAVCAN_STM32_CHIBIOS=1 -DGIT_HASH=0x7719d6e -DSTDOUT_SD=SD1 -DSTDIN_SD=STDOUT_SD -DSERIAL_CLI_PORT_NUMBER=1 -DCORTEX_ENABLE_WFI_IDLE=1 -fno-single-precision-constant -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -MD -MP -MF .dep/build.d -I. -Izubax_chibios///chibios/os/rt/ports/ARMCMx -Izubax_chibios///chibios/os/rt/ports/ARMCMx/compilers/GCC -Izubax_chibios///chibios/os/rt/include -Izubax_chibios///chibios/os/hal/include -Izubax_chibios//chibios/os/hal/ports/common/ARMCMx -Izubax_chibios//chibios/os/hal/ports/STM32/STM32F1xx -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/CANv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/DACv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/DMAv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/EXTIv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/GPIOv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/I2Cv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/MACv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/OTGv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/RTCv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/SDIOv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/SPIv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/TIMv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/USARTv1 -Izubax_chibios//chibios/os/hal/ports/STM32/LLD/xWDGv1 -Izubax_chibios///chibios/os/various/cpp_wrappers -Izubax_chibios///chibios/os/common/ports/ARMCMx/compilers/GCC -Izubax_chibios///chibios/os/common/ports/ARMCMx/devices/STM32F1xx -Izubax_chibios///chibios/os/ext/CMSIS/include -Izubax_chibios///chibios/os/ext/CMSIS/ST/STM32F1xx -Izubax_chibios///chibios/os/hal/osal/rt -Izubax_chibios///chibios/os/various -Izubax_chibios///chibios/os/hal/lib/streams -Isrc -Isrc/os_config -Ilibuavcan/libuavcan/include -Ilibuavcan/libuavcan_drivers/stm32/driver/include/ -Idsdlc_generated -Izubax_chibios// main.c -o main.o
Compiling crt0_v7m.s
Compiling chcoreasm_v7m.s
Compiling motor.c
Compiling rpmctl.c
Compiling motor_adc.c
Compiling motor_rtctl.c
Compiling motor_pwm.c
Compiling motor_debug_cli.c
Compiling motor_forced_rotation_detection.c
Compiling motor_rtctl_test.c
Compiling motor_timer.c
Compiling crt1.c
Compiling vectors.c
Compiling chsys.c
Compiling chdebug.c
Compiling chvt.c
Compiling chschd.c
Compiling chthreads.c
Compiling chtm.c
Compiling chstats.c
Compiling chdynamic.c
Compiling chregistry.c
Compiling chsem.c
Compiling chmtx.c
Compiling chcond.c
Compiling chevents.c
Compiling chmsg.c
Compiling chmboxes.c
Compiling chqueues.c
Compiling chmemcore.c
Compiling chheap.c
Compiling chmempools.c
Compiling chcore.c
Compiling chcore_v7m.c
Compiling osal.c
Compiling hal.c
Compiling hal_buffers.c
Compiling hal_queues.c
Compiling hal_mmcsd.c
Compiling adc.c
Compiling can.c
Compiling dac.c
Compiling ext.c
Compiling gpt.c
Compiling i2c.c
Compiling i2s.c
Compiling icu.c
Compiling mac.c
Compiling mmc_spi.c
Compiling pal.c
Compiling pwm.c
Compiling rtc.c
Compiling sdc.c
Compiling serial.c
Compiling serial_usb.c
Compiling spi.c
Compiling st.c
Compiling uart.c
Compiling usb.c
Compiling wdg.c
Compiling nvic.c
Compiling hal_lld.c
Compiling adc_lld.c
Compiling ext_lld_isr.c
Compiling can_lld.c
Compiling dac_lld.c
Compiling stm32_dma.c
Compiling ext_lld.c
Compiling pal_lld.c
Compiling i2c_lld.c
Compiling mac_lld.c
Compiling usb_lld.c
Compiling rtc_lld.c
Compiling sdc_lld.c
Compiling spi_lld.c
Compiling gpt_lld.c
Compiling icu_lld.c
Compiling pwm_lld.c
Compiling st_lld.c
Compiling serial_lld.c
Compiling uart_lld.c
Compiling wdg_lld.c
Compiling syscalls.c
Compiling chprintf.c
Compiling memstreams.c
Compiling shell.c
Compiling pwm_input.cpp
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
Compiling temperature_sensor.cpp
Compiling console.cpp
In file included from libuavcan/libuavcan/include/uavcan/marshal/types.hpp:10:0,
from dsdlc_generated/uavcan/Timestamp.hpp:14,
from libuavcan/libuavcan/include/uavcan/time.hpp:12,
from libuavcan/libuavcan/include/uavcan/uavcan.hpp:11,
from libuavcan/libuavcan_drivers/stm32/driver/include/uavcan_stm32/uavcan_stm32.hpp:7,
from src/uavcan_node/uavcan_node.hpp:37,
from /home/philippe/sapog/firmware/src/console.cpp:47:
libuavcan/libuavcan/include/uavcan/marshal/array.hpp: In instantiation of 'uavcan::Array<T, ArrayMode, MaxSize_>::SelfType& uavcan::Array<T, ArrayMode, MaxSize_>::operator=(const char*) [with T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 80u; uavcan::Array<T, ArrayMode, MaxSize_>::SelfType = uavcan::Array<uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>, (uavcan::ArrayMode)1u, 80u>]':
libuavcan/libuavcan/include/uavcan/protocol/data_type_info_provider.hpp:82:23: required from here
libuavcan/libuavcan/include/uavcan/marshal/array.hpp:828:15: warning: declaration of 'ch' shadows a global declaration [-Wshadow]
SelfType& operator=(const char* ch)
In file included from zubax_chibios///chibios/os/rt/include/ch.h:78:0,
from /home/philippe/sapog/firmware/src/console.cpp:40:
zubax_chibios///chibios/os/rt/include/chschd.h:521:20: note: shadowed declaration is here
extern ch_system_t ch;
Compiling main.cpp
from /home/philippe/sapog/firmware/src/main.cpp:48:
from /home/philippe/sapog/firmware/src/main.cpp:35:
Compiling indication_controller.cpp
from /home/philippe/sapog/firmware/src/uavcan_node/indication_controller.hpp:37,
from /home/philippe/sapog/firmware/src/uavcan_node/indication_controller.cpp:35:
from zubax_chibios///chibios/os/various/cpp_wrappers/ch.hpp:25,
from libuavcan/libuavcan_drivers/stm32/driver/include/uavcan_stm32/thread.hpp:10,
from libuavcan/libuavcan_drivers/stm32/driver/include/uavcan_stm32/uavcan_stm32.hpp:9,
Compiling bootloader_interface.cpp
Compiling uavcan_node.cpp
from /home/philippe/sapog/firmware/src/uavcan_node/uavcan_node.hpp:37,
from /home/philippe/sapog/firmware/src/uavcan_node/uavcan_node.cpp:35:
libuavcan/libuavcan/include/uavcan/marshal/array.hpp: In instantiation of 'uavcan::Array<T, ArrayMode, MaxSize_>::SelfType& uavcan::Array<T, ArrayMode, MaxSize_>::operator=(const char*) [with T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 92u; uavcan::Array<T, ArrayMode, MaxSize_>::SelfType = uavcan::Array<uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>, (uavcan::ArrayMode)1u, 92u>]':
/home/philippe/sapog/firmware/src/uavcan_node/uavcan_node.cpp:115:13: required from here
libuavcan/libuavcan/include/uavcan/marshal/array.hpp: In instantiation of 'bool uavcan::Array<T, ArrayMode, MaxSize_>::operator==(const char*) const [with T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 92u]':
libuavcan/libuavcan/include/uavcan/marshal/array.hpp:822:87: required from 'bool uavcan::Array<T, ArrayMode, MaxSize_>::operator!=(const R&) const [with R = char [10]; T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 92u]'
/home/philippe/sapog/firmware/src/uavcan_node/uavcan_node.cpp:293:61: required from here
libuavcan/libuavcan/include/uavcan/marshal/array.hpp:810:10: warning: declaration of 'ch' shadows a global declaration [-Wshadow]
bool operator==(const char* ch) const
libuavcan/libuavcan/include/uavcan/marshal/array.hpp: In instantiation of 'uavcan::Array<T, ArrayMode, MaxSize_>::SelfType& uavcan::Array<T, ArrayMode, MaxSize_>::operator+=(const char*) [with T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 80u; uavcan::Array<T, ArrayMode, MaxSize_>::SelfType = uavcan::Array<uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>, (uavcan::ArrayMode)1u, 80u>]':
libuavcan/libuavcan/include/uavcan/marshal/array.hpp:694:23: required from 'uavcan::Array<T, ArrayMode, MaxSize_>::Array(const char*) [with T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 80u]'
/home/philippe/sapog/firmware/src/uavcan_node/uavcan_node.cpp:411:36: required from here
libuavcan/libuavcan/include/uavcan/marshal/array.hpp:848:15: warning: declaration of 'ch' shadows a global declaration [-Wshadow]
SelfType& operator+=(const char* ch)
libuavcan/libuavcan/include/uavcan/marshal/array.hpp: In instantiation of 'uavcan::Array<T, ArrayMode, MaxSize_>::SelfType& uavcan::Array<T, ArrayMode, MaxSize_>::operator=(const char*) [with T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 31u; uavcan::Array<T, ArrayMode, MaxSize_>::SelfType = uavcan::Array<uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>, (uavcan::ArrayMode)1u, 31u>]':
libuavcan/libuavcan/include/uavcan/protocol/logger.hpp:266:29: required from 'int uavcan::Logger::log(uavcan::Logger::LogLevel, const char*, const char*, Args ...) [with Args = {}; uavcan::Logger::LogLevel = unsigned char]'
libuavcan/libuavcan/include/uavcan/node/node.hpp:74:9: required from 'void uavcan::Node<MemPoolSize>::registerInternalFailure(const char*) [with unsigned int MemPoolSize = 7168u]'
/home/philippe/sapog/firmware/src/uavcan_node/uavcan_node.cpp:600:1: required from here
libuavcan/libuavcan/include/uavcan/marshal/array.hpp: In instantiation of 'uavcan::Array<T, ArrayMode, MaxSize_>::SelfType& uavcan::Array<T, ArrayMode, MaxSize_>::operator+=(const char*) [with T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 90u; uavcan::Array<T, ArrayMode, MaxSize_>::SelfType = uavcan::Array<uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>, (uavcan::ArrayMode)1u, 90u>]':
libuavcan/libuavcan/include/uavcan/marshal/array.hpp:916:21: required from 'void uavcan::Array<T, ArrayMode, MaxSize_>::appendFormatted(const char*, A) [with A = const char*; T = uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>; uavcan::ArrayMode ArrayMode = (uavcan::ArrayMode)1u; unsigned int MaxSize_ = 90u]'
libuavcan/libuavcan/include/uavcan/marshal/char_array_formatter.hpp:66:9: required from 'void uavcan::CharArrayFormatter<ArrayType_>::writeValue(const char*) [with ArrayType_ = uavcan::Array<uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>, (uavcan::ArrayMode)1u, 90u>]'
libuavcan/libuavcan/include/uavcan/marshal/char_array_formatter.hpp:81:24: required from 'void uavcan::CharArrayFormatter<ArrayType_>::write(const char*) [with ArrayType_ = uavcan::Array<uavcan::IntegerSpec<8u, (uavcan::Signedness)0u, (uavcan::CastMode)0u>, (uavcan::ArrayMode)1u, 90u>]'
libuavcan/libuavcan/include/uavcan/protocol/logger.hpp:269:13: required from 'int uavcan::Logger::log(uavcan::Logger::LogLevel, const char*, const char*, Args ...) [with Args = {}; uavcan::Logger::LogLevel = unsigned char]'
Compiling esc_controller.cpp
from /home/philippe/sapog/firmware/src/uavcan_node/esc_controller.hpp:37,
from /home/philippe/sapog/firmware/src/uavcan_node/esc_controller.cpp:35:
Compiling board.cpp
Compiling led.cpp
Compiling uc_dispatcher.cpp
Compiling uc_transfer_listener.cpp
Compiling uc_frame.cpp
Compiling uc_transfer_sender.cpp
Compiling uc_transfer_receiver.cpp
Compiling uc_can_acceptance_filter_configurator.cpp
Compiling uc_crc.cpp
Compiling uc_outgoing_transfer_registry.cpp
Compiling uc_can_io.cpp
Compiling uc_transfer_buffer.cpp
Compiling uc_transfer.cpp
Compiling uc_bit_array_copy.cpp
Compiling uc_scalar_codec.cpp
Compiling uc_bit_stream.cpp
Compiling uc_float_spec.cpp
Compiling uc_dynamic_node_id_client.cpp
Compiling uc_node_status_provider.cpp
Compiling uc_can.cpp
Compiling uc_error.cpp
Compiling uc_generic_subscriber.cpp
Compiling uc_service_client.cpp
Compiling uc_timer.cpp
Compiling uc_generic_publisher.cpp
Compiling uc_global_data_type_registry.cpp
Compiling uc_scheduler.cpp
Compiling uc_data_type.cpp
Compiling uc_dynamic_memory.cpp
Compiling uc_stm32_thread.cpp
from libuavcan/libuavcan_drivers/stm32/driver/include/uavcan_stm32/thread.hpp:26,
from libuavcan/libuavcan_drivers/stm32/driver/src/uc_stm32_thread.cpp:5:
Compiling uc_stm32_clock.cpp
from libuavcan/libuavcan/include/uavcan/driver/system_clock.hpp:11,
from libuavcan/libuavcan_drivers/stm32/driver/include/uavcan_stm32/clock.hpp:8,
from libuavcan/libuavcan_drivers/stm32/driver/src/uc_stm32_clock.cpp:5:
from libuavcan/libuavcan_drivers/stm32/driver/src/uc_stm32_clock.cpp:6:
Compiling uc_stm32_can.cpp
from libuavcan/libuavcan_drivers/stm32/driver/include/uavcan_stm32/can.hpp:8,
from libuavcan/libuavcan_drivers/stm32/driver/src/uc_stm32_can.cpp:7:
Compiling sys_stm32.cpp
Compiling watchdog_stm32.cpp
Compiling libstdcpp.cpp
Compiling sys_console.cpp
Compiling sys.cpp
Compiling config.cpp
Compiling config_cli.cpp
Compiling ch.cpp
Compiling syscalls_cpp.cpp
Linking build/io.px4.sapog.elf
Creating build/io.px4.sapog.bin
# Building the bootloader
cd /home/philippe/sapog/bootloader && make
make[1]: Entering directory '/home/philippe/sapog/bootloader'
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/home/philippe/sapog/bootloader'
# Removing previous build outputs that could use a different git hash
rm -rf build/*.uavcan.bin build/*.compound.bin
# Generating compound image with embedded bootloader
cd build && dd if=/dev/zero bs=16384 count=1 | tr "\000" "\377" >padded_bootloader.tmp.bin
1+0 records in
1+0 records out
16384 bytes (16 kB, 16 KiB) copied, 4,8337e-05 s, 339 MB/s
cd build && dd if=/home/philippe/sapog/bootloader/build/bootloader.bin of=padded_bootloader.tmp.bin conv=notrunc
15+1 records in
15+1 records out
7933 bytes (7,9 kB, 7,7 KiB) copied, 0,000148278 s, 53,5 MB/s
cd build && cat padded_bootloader.tmp.bin io.px4.sapog.bin >io.px4.sapog-1-2.2.7719d6e.compound.bin
# Generating the signed image for the bootloader
cd build && ../zubax_chibios/tools/make_boot_descriptor.py io.px4.sapog.bin io.px4.sapog 1 \
--also-patch-descriptor-in=io.px4.sapog.elf \
--also-patch-descriptor-in=io.px4.sapog-1-2.2.7719d6e.compound.bin
# Injecting the bootloader into the final ELF; note that we're using unpadded bootloader to preserve signature
cd build && arm-none-eabi-objcopy --add-section bootloader=/home/philippe/sapog/bootloader/build/bootloader.bin \
--set-section-flags bootloader=load,alloc \
--change-section-address bootloader=0x08000000 \
io.px4.sapog.elf compound.elf
arm-none-eabi-objcopy: compound.elf: warning: allocated section `bootloader' not in segment
# Removing temporary files
cd build && rm -f io.px4.sapog.bin io.px4.sapog.elf *.hex *.tmp.bin
flash command :
philippe@philippe-MS-7641:~/sapog/tools$ ./blackmagic_flash.sh /dev/ttyACM0
text data bss dec hex filename
141112 10598 43564 195274 2faca compound.elf
Target voltage: 0.0V
Available Targets:
No. Att Driver
1 STM32F1 high density
0x08005aa2 in __udivdi3 ()
Loading section bootloader, size 0x1efd lma 0x8000000
Loading section startup, size 0x180 lma 0x8004000
Loading section constructors, size 0x4 lma 0x8004180
Loading section .padding1, size 0xc lma 0x8004184
Loading section .text, size 0x22730 lma 0x8004190
Loading section .ARM.exidx, size 0x8 lma 0x80268c0
Loading section .data, size 0x8d4 lma 0x80268c8
Loading section .noinit, size 0x5 lma 0x802719c
Start address 0x8004190, load size 151710
Transfer rate: 18 KB/sec, 936 bytes/write.
Kill the program being debugged? (y or n) [answered Y; input not from terminal]
content of the build directory
philippe@philippe-MS-7641:~/sapog/firmware/build$ ls -l
total 1760
-rwxrwxr-x 1 philippe philippe 320248 févr. 14 14:43 compound.elf
-rw-rw-r-- 1 philippe philippe 143784 févr. 14 14:43 io.px4.sapog-1-2.2.7719d6e.application.bin
-rw-rw-r-- 1 philippe philippe 160161 févr. 14 14:43 io.px4.sapog-1-2.2.7719d6e.compound.bin
-rw-rw-r-- 1 philippe philippe 1193328 févr. 14 14:43 io.px4.sapog.map
drwxrwxr-x 2 philippe philippe 4096 févr. 14 14:43 lst
drwxrwxr-x 2 philippe philippe 4096 févr. 14 14:43 obj
Thank you, Philippe. The outputs look good. You said above that your hardware is an official Orel 20, but you also said in the beginning:
How did you come to own an Orel 20 with a bare MCU?
Regardless, please run another test: try uploading the attached file and see if it changes anything:
compound.elf (1.8 MB)
Please also describe the behavior of the LED indicator after the board is powered on.
Thanks Pavel,
We have two official Orel 20 and also made two custom modified board based on the zubax design.
As we saw that the flashing was not working on our custom board, we tried flashing the official Orel 20, that stopped working after the flashing. I will try to flash your file.
led status after powering up. Orange fixed during several seconds. Then blue/red for one two seconds, then green fixed.
here is the result of the flashing with your file :
191320 10601 43612 245533 3bf1d compound.elf
Available Targets:
No. Att Driver
0x08009fb0 in registerDataType (id=…, this=0x0) at libuavcan/libuavcan/include/uavcan/node/global_data_type_registry.hpp:214
214 libuavcan/libuavcan/include/uavcan/node/global_data_type_registry.hpp: No such file or directory.
Loading section .text, size 0x2eb50 lma 0x8004190
Loading section .ARM.exidx, size 0x8 lma 0x8032ce0
Loading section .data, size 0x8d4 lma 0x8032ce8
Loading section .noinit, size 0x8 lma 0x80335bc
Start address 0x8004190, load size 201921
Transfer rate: 18 KB/sec, 947 bytes/write.
there is a missing file ?
