Hello, I have an error when compiling Zubax_gnss, but I don’t know how to solve it. Can someone answer it for me? Maybe this is a little white question!![]()
I already Install ARM GCC toolchain version 6.3 or newer
If you read the error message, it clearly indicates that the compiler does not support the flag -Wimplicit-fallthrough, which implies that it is of a wrong (old) version.
Hello, this is the version I am currently using, do I need to update it?
This version should work. If it still doesn’t, perhaps you have another version installed which is not working. Otherwise consider upgrading to 7.3 and use the current master.
