yelang
January 9, 2019, 1:47am
1
dear Pavel Kirienko:
in publisher tutorial all the data type signature is 64bit ,
in px4 pasog BootLoader all the data type signature is 16bit.
they have the different data signature, Why can they communicate with GUI?both fine.
i know that the data signature is Not transmitted , only store at the both side code , to be as a extra crc to
add crc16(payload) , right?
2 . if orel esc have a pasog bootloader can i use the uavcan gui tool to update application firmware for it?
thank you very much!
The PX4 bootloader code contains a mistake: what they call “signature” is not, in fact, a signature; rather it’s the CRC16 of the signature. They store precomputed CRC16 of the signature to accelerate runtime CRC computation. This is a correct and compliant approach as far as the UAVCAN specification is concerned, but the naming is suboptimal.
Yes, this bootloader can be used with the GUI tool.
yelang
January 10, 2019, 3:11am
3
cool,very professional! i like you , guru.
In the example on this page , I didn’t understand how to get the SIGNATURE we have to put for a given DSDL message we sent from a sensor node. Thanks
The signatures can be obtained using this simple script:
https://github.com/UAVCAN/libcanard/blob/master/show_data_type_info.py
Here is the output of this script for the standard namespace uavcan:
Full Data Type Name | DDTID | Type Signature | Max Bit Len
uavcan.CoarseOrientation N/A 0x271ba10b0dac9e52 16
uavcan.Timestamp N/A 0x05bd0b5c81087e0d 56
uavcan.equipment.actuator.ArrayCommand 1010 0xd8a7486238ec3af3 484
uavcan.equipment.actuator.Command N/A 0x8d9a6a920c1d616c 32
uavcan.equipment.actuator.Status 1011 0x5e9bba44faf1ea04 64
uavcan.equipment.ahrs.MagneticFieldStrength 1001 0xe2a7d4a9460bc2f2 196
uavcan.equipment.ahrs.MagneticFieldStrength2 1002 0xb6ac0c442430297e 204
uavcan.equipment.ahrs.RawIMU 1003 0x8280632c40e574b5 958
uavcan.equipment.ahrs.Solution 1000 0x72a63a3c6f41fa9b 668
uavcan.equipment.air_data.AngleOfAttack 1025 0xd5513c3f7afac74e 40
uavcan.equipment.air_data.IndicatedAirspeed 1021 0x0a1892d72ab8945f 32
uavcan.equipment.air_data.RawAirData 1027 0xc77df38ba122f5da 397
uavcan.equipment.air_data.Sideslip 1026 0x7b48e55fcff42a57 32
uavcan.equipment.air_data.StaticPressure 1028 0xcdc7c43412bdc89a 48
uavcan.equipment.air_data.StaticTemperature 1029 0x49272a6477d96271 32
uavcan.equipment.air_data.TrueAirspeed 1020 0x306f69e0a591afaa 32
uavcan.equipment.camera_gimbal.AngularCommand 1040 0x4af6e57b2b2be29c 80
uavcan.equipment.camera_gimbal.GEOPOICommand 1041 0x9371428a92f01fd6 104
uavcan.equipment.camera_gimbal.Mode N/A 0x9108c7785aeb69c4 8
uavcan.equipment.camera_gimbal.Status 1044 0xb9f127865be0d61e 228
uavcan.equipment.device.Temperature 1110 0x70261c28a94144c6 40
uavcan.equipment.esc.RPMCommand 1031 0xce0f9f621cf7e70b 365
uavcan.equipment.esc.RawCommand 1030 0x217f5c87d7ec951d 285
uavcan.equipment.esc.Status 1034 0xa9af28aea2fbb254 110
uavcan.equipment.gnss.Auxiliary 1061 0x9be8bdc4c3dbbfd2 125
uavcan.equipment.gnss.ECEFPositionVelocity N/A 0x24a5da4abee3a248 792
uavcan.equipment.gnss.Fix 1060 0x54c1572b9e07f297 628
uavcan.equipment.gnss.Fix2 1063 0xca41e7000f37435f 1769
uavcan.equipment.gnss.RTCMStream 1062 0x1f56030ecb171501 1040
uavcan.equipment.hardpoint.Command 1070 0xa1a036268b0c3455 24
uavcan.equipment.hardpoint.Status 1071 0x624a519d42553d82 56
uavcan.equipment.ice.FuelTankStatus 1129 0x286b4a387ba84bc4 104
uavcan.equipment.ice.reciprocating.CylinderStatus N/A 0xd68ac83a89d5b36b 80
uavcan.equipment.ice.reciprocating.Status 1120 0xd38aa3ee75537ec6 1565
uavcan.equipment.indication.BeepCommand 1080 0xbe9ea9fec2b15d52 32
uavcan.equipment.indication.LightsCommand 1081 0x2031d93c8bdd1ec4 485
uavcan.equipment.indication.RGB565 N/A 0x58a7cef41951ec34 16
uavcan.equipment.indication.SingleLightCommand N/A 0xe894b8b589807007 24
uavcan.equipment.power.BatteryInfo 1092 0x249c26548a711966 437
uavcan.equipment.power.CircuitStatus 1091 0x8313d33d0ddda115 56
uavcan.equipment.power.PrimaryPowerSupplyStatus 1090 0xbba05074ad757480 47
uavcan.equipment.range_sensor.Measurement 1050 0x68fffe70fc771952 120
uavcan.equipment.safety.ArmingStatus 1100 0x8700f375556a8003 8
uavcan.navigation.GlobalNavigationSolution 2000 0x463b10cccbe51c3d 1860
uavcan.protocol.AccessCommandShell 6 0x59276b5921c9246e 1040 / 2097
uavcan.protocol.CANIfaceStats N/A 0x13b106f0c44ca350 144
uavcan.protocol.DataTypeKind N/A 0x9420a73e008e5930 8
uavcan.protocol.GetDataTypeInfo 2 0x1b283338a7bed2d8 671 / 743
uavcan.protocol.GetNodeInfo 1 0xee468a8121c46a9e 0 / 3015
uavcan.protocol.GetTransportStats 4 0xbe6f76a7ec312b04 0 / 578
uavcan.protocol.GlobalTimeSync 4 0x20271116a793c2db 56
uavcan.protocol.HardwareVersion N/A 0x0ad5c4c933f4a0c4 2192
uavcan.protocol.NodeStatus 341 0x0f0868d0c1a7c6f1 56
uavcan.protocol.Panic 5 0x8b79b4101811c1d7 59
uavcan.protocol.RestartNode 5 0x569e05394a3017f0 40 / 1
uavcan.protocol.SoftwareVersion N/A 0xdd46fd376527fea1 120
uavcan.protocol.debug.KeyValue 16370 0xe02f25d6e0c98ae0 502
uavcan.protocol.debug.LogLevel N/A 0x711bf141af572346 3
uavcan.protocol.debug.LogMessage 16383 0xd654a48e0c049d75 983
uavcan.protocol.dynamic_node_id.Allocation 1 0x0b2a812620a11d40 141
uavcan.protocol.dynamic_node_id.server.AppendEntries 30 0x8032c7097b48a3cc 249 / 33
uavcan.protocol.dynamic_node_id.server.Discovery 390 0x821ae2f525f69f21 51
uavcan.protocol.dynamic_node_id.server.Entry N/A 0x7faa779d64fa75c2 168
uavcan.protocol.dynamic_node_id.server.RequestVote 31 0xcdde07bb89a56356 72 / 33
uavcan.protocol.enumeration.Begin 15 0x196ae06426a3b5d8 759 / 8
uavcan.protocol.enumeration.Indication 380 0x884cb63050a84f35 815
uavcan.protocol.file.BeginFirmwareUpdate 40 0xb7d725df72724126 1616 / 1031
uavcan.protocol.file.Delete 47 0x78648c99170b47aa 1608 / 16
uavcan.protocol.file.EntryType N/A 0x6924572fbb2086e5 8
uavcan.protocol.file.Error N/A 0xa83071ffea4fae15 16
uavcan.protocol.file.GetDirectoryEntryInfo 46 0x8c46e8ab568bda79 1640 / 1632
uavcan.protocol.file.GetInfo 45 0x5004891ee8a27531 1608 / 64
uavcan.protocol.file.Path N/A 0x12aefc50878a43e2 1608
uavcan.protocol.file.Read 48 0x8dcdca939f33f678 1648 / 2073
uavcan.protocol.file.Write 49 0x515aa1dc77e58429 3192 / 16
uavcan.protocol.param.Empty N/A 0x6c4d0e8ef37361df 0
uavcan.protocol.param.ExecuteOpcode 10 0x3b131ac5eb69d2cd 56 / 49
uavcan.protocol.param.GetSet 11 0xa7b622f939d1a4d5 1791 / 2967
uavcan.protocol.param.NumericValue N/A 0x0da6d6fea22e3587 66
uavcan.protocol.param.Value N/A 0x29f14bf484727267 1035
This will not be needed in UAVCAN v1, because we have removed the concept of data type signature. UAVCAN v1 in this sense is much simpler than v0.
