Updating firmware make -j8 says "File not found - *.cpp"
I am trying to use the Zubax Babel CF1 with the UAVCAN GUI Tool, but I am getting wrong CAN behavior on the bus when I connect the babel to the gui tool. I think I might need to flash firmware to the Babel, so I am following the steps laid out here: https://github.com/Zubax/canface_cf1?tab=readme-ov-file
When I try to build the code using this command in Command Prompt,
make -j8 RELEASE=1
I get this output,
> C:\Users\SethReed\canface_cf1\firmware>make -j8 RELEASE=1
> The system cannot find the path specified.
> The syntax of the command is incorrect.
> make: *** [zubax_chibios///chibios/os/common/ports/ARMCMx/compilers/GCC/rules.mk:174: build/obj] Error 1
> make: *** Waiting for unfinished jobs....
> make: *** [zubax_chibios///chibios/os/common/ports/ARMCMx/compilers/GCC/rules.mk:177: build/lst] Error 1
I am currently running Windows10. This is the version of ARM GCC that I installed too.
If anyone has suggestions for what to do, that would be greatly appreciated. Thanks!
Globs don’t work on Windows. Use a different OS.
