Telega Phase Current
Telega publishes information about AC current in two places:
  • phase_current_amplitude in the compact topic
  • current[2] in the dq topic
How do I calculate the RMS current per phase from these measurements? Is it
  • phase current amplitude divided by \sqrt{2} because the published amplitude is per-phase,
  • something with \sqrt{3} because the published amplitude is for the 3-phase AC system,
  • a combination of the above or something else?
Lasse :slight_smile:
The per-phase RMS current is \frac{i_{\text{peak}}}{\sqrt{2}}
so the RMS is phase_current_amplitude/sqrt(2)
or equivalently \frac{\sqrt{\texttt{dq.current[0]}^2+\texttt{dq.current[1]}^2}}{\sqrt{2}}
These may be distorted if your motor’s flux is strongly non-sinusoidal.
The Clarke/Park implementation is the amplitude-preserving form so |i_dq| matches the sinusoidal phase peak.
