I’ve been doing some wind tunnel testing of a propulsion system with a few controllers; and I am very happy about the efficiency gains I am seeing with the Myxa when comparing to others ESCs. During testing, several questions have come up and I’m hoping the forum can help answer:
In current control mode, even with oversaturate turned on, the maximum RPM is less than than other ESCs we are testing. Is there anything else we can do to get a higher rpm (about 5% higher).
Does the myxa’s aluminum enclosure have thermal paste inside which will need to be replaced if we open the case? (We are considering swapping the bullet plugs to a larger size to adapt to our setup)
We require a brake when going to idle throttle; it looks like it will hopefully be in the next firmware release. Is there any update on when we can expect this?
In voltage and RPM control mode, ramping down the throttle quickly will send power back to our power supply and cause it to over-voltage shutdown. Is this expected?, and could this potentially damage other electronics when installed on an aircraft? Why does this not occur in current control mode?
If I am controlling the Mxya over RCPWM, do I have to connect the 5V wire between the flight controller and the mxya’s AUX_VDD port?
What does the ctl.hard_stop parameter do? What does the rcpwm. hysteresis parameter do?
