Questions about the firmware
I downloaded the firmware at GITHUB. Why BOOTLOAD can make make a success directly, but there are many errors and problems when making the firmware make? For example, now. It prompts me: zubax_chibios//_rules_armcm.mk:35: *** USE_PROCESS_STACKSIZE is not defined. Stop.
When I open _rules_armcm.mk, this is the case.
34 ifndef USE_PROCESS_STACKSIZE
35 $(error USE_PROCESS_STACKSIZE is not defined)
36 endif
I don’t know where USE_PROCESS_STACKSIZE should be defined.
Is it a problem with my system or where is the problem.
THINKS.
Remove the archive you have downloaded from GitHub and clone the repository properly instead:
git clone --recursive https://github.com/PX4/sapog
