Problems with Babel & UAVCAN Gui Tool on Windows
I’m having problems using the Babel board with UAVCAN Gui Tool on Windows.
When I connect the Babel board via USB and start UAVCAN Gui Tool (v 0.8 I think) the drop down menu under “Select CAN Interface” is empty.
Therefore I can’t get past the “CAN Interface Configuration” dialog.
Any help with this would be appreciated (It works fine on my Linux desktop but I’m using a windows laptop outside).
Derek
If you’re using any Windows version earlier than Windows 10, you need to install drivers as described here: docs.zubax.com/usb#Configuring_ … of_Windows
If you’re using Windows 10, or if you’ve already installed drivers, and it still doesn’t work, please take a screenshot of your Device Manager window with Babel connected.
