I have a EPM V3R4 and had a std telemetry cable for a older Pixhawk 4. I want to move it to a Pixhawk 2.1, but the telemetry cables have changed. Does anyone know where I can get the cable necessary?
I am not sure what are you referring to as “telemetry cable”. Is it the UAVCAN patch cable? All versions of Pixhawk including v2.1 follow the Dronecode Autopilot Connector Standard, which has not been changed in a while.
Sorry Pavel, I actually meant the UAVCAN cable. The cable for the older Pixhawk had a different type of connector than is being used on the Pixhawk 2.1 I’ve also been having cable issues on moving the uAvionics pingRX which uses the telemetry port.
Sounds like you need this: mRo 4-Pin DF13 to 4-Pin JST-GH
