Hello, is there a way to control one LED of the Myxa?
Ideally, I would love to send an UAVCAN message to control the led, is that possible?
Hi Philippe,
Yes, it will be possible in the next released version of Telega. The external LED should be connected to the GPIO2 pin of the AUX connector. The LED should be connected in series with 200 Ohm resistor. You can connect also the mosfet switch to the gpio2 pin in order to drive the high power led or any other device.
