Myxa ESC Max Regen Current
In regen conditions, is there a max current for the Myxa ESC for DC current flowing from the ESC into the battery? The Myxa datasheet max DC continuous current is +60A. For the regen case, the DC current would be negative, so would the max negative current be -60A.
We are performing some wind tunnel tests using a 4-quadrant power supply able to sink large amounts of current, and the regen current may increase higher than possible in any real flight situations.
The limit given in the datasheet is absolute. You will likely run into stability issues before reaching the regen current of 60 A, though. May I recommend switching to Telega v1 instead?
