While tuning spin-up behavior with new propellers on six Myxa B0 devices, a single device suddenly stopped working:
- the device does publish a heartbeat, reporting healthy and operational
- the device does reboot when instructed to do so (
yakut cmd 11 reboot) - the device does not respond to a drive command (
setpoint_velocitysubscription), it remains in standby mode - the device does not perform a self test when instructed via
yakut cmd 11 1, it remains in standby - the device’s
sys.statusregister never shows anything else than{"standby":{}}
Both the drive and self test command result in five other devices on the same bus to spin up, or perform a self test, respectively. Before the malfunction, the device itself also worked without any issues.
Is there anything I can do?
device ID: 32004a00075030503034392000000000
configuration dump: myxa-not-repsonding.yaml (3.9 KB)
Edit: some more observations
- Sometimes when receiving a drive setpoint, the device reports health: CAUTION with a VSSC of 0x5e, indicating some kind of hardware error. Usually health is nominal with a VSSC of 0x53, though.
- When in health: CAUTION mode, the device reports “other” faults,e.g. the
fault_flags.otherbit inside thestatuspublication is set.
