Hello everyone!
I couldn’t modify the original 3D Printed Myxa case so I’ve designed one here.
Zubax Myxa ESC Case - Printables
I’ve whipped up a simple, lightweight case for your Myxa ESCs. It tackles two nagging issues with the stock enclosure:
- Mounting compatibility: It screws tight, right onto the 16 mm tube mounts I’m using. You’d change it for your application.
- Total customisability: You get the included
.stepfile, so you can tweak dimensions, add cutouts, and change mounting pattern - Instant ID marking: There’s a built‑in label on the top half—currently mine reads “ESC 001,” but you could mark in your DroneCAN (Cyphal) node number, or prop‑spin direction
Pictures coming soon—prepare for an ESC glow‑up!
Have fun!
