I am facing an issue while using T-Motor F60 Pro III 2207 / 2500KV with UAVCAN GUI and Holybro Kotleta20 ESC. When I use ESC Panel to send throttle command it stops (cuts off) and not rotating perfectly at 57% as seen in the attached video. I don’t know what is the problem exactly. When trying the same process with DJI E305 2312E / 960KV it is working perfectly until 100%. ESC configuration attached.
Does this means this ESC is suitable for low KV?
