Kucher v1.1 is released for Windows and GNU/Linux
Kucher v1.1 is now available. This maintenance release upgrades the dependencies to the latest versions and fixes known stability issues.
Here are the direct download links:
  • GNU/Linux: Redirecting.... Tested against Manjaro and Ubuntu, should work with all modern distros out of the box.
  • Windows: Redirecting.... The Windows version is designed to work with Windows 11 and 10, compatibility with older releases is possible but not guaranteed. As of right now, the Windows executable is not yet digitally signed, but this is expected to be corrected soon; meanwhile, please configure your Windows Security service to accept Kucher.exe as safe.
The executables are portable and require no installation, just download and run. You may need to set up your USB connection as described here: Knowledge base | Zubax Wiki
You can still run the application from sources as well, of course:
https://github.com/Zubax/kucher
Kucher is free software available under the terms of GNU GPL v3.
