I am trying to connect Zubax with Kucher (Linux application) thanks to a virtual port.
The virtual port is created with this command :
sudo socat PTY,link=/dev/ttyUSB5,raw,group-late=dialout,mode=660 TCP:192.168.31.20:5005
I am able to connect to Zubax via pySerial. Do you have a command to send to Zubax to know if I can interact with it via pySerial?
Kucher (Linux application) do not looking for virtual port, so I forced the virtual port inside the application code (selected_port variable inside kucher/view/main_window/device_management_widget/__init__.py) and I have an error when Kucher try to communicate with Zubax. This is the error:
2020-06-11 11:33:07,137 pid=12930 ERROR: kucher.view.utils: Error window: title='Could not connect', text='Connection via the port /dev/pts/6 could not be established.', informative_text='Reason: Node info request has timed out', parent=<kucher.view.main_window.device_management_widget.DeviceManagementWidget object at 0x7fb037f13d38>
Traceback (most recent call last):
File "/home/florian/Téléchargements/kucher/kucher/view/main_window/device_management_widget/__init__.py", line 222, in _do_connect
device_info: BasicDeviceInfo = await self._connection_request_callback(selected_port)
File "/home/florian/Téléchargements/kucher/kucher/fuhrer/__init__.py", line 66, in _on_connection_request
device_info = await self._device_model.connect(port_name=port, on_progress_report=on_progress_report)
File "/home/florian/Téléchargements/kucher/kucher/model/device_model/__init__.py", line 135, in connect
general_status_update_period=DEFAULT_GENERAL_STATUS_UPDATE_PERIOD)
File "/home/florian/Téléchargements/kucher/kucher/model/device_model/connection.py", line 301, in connect
raise ConnectionAttemptFailedException('Node info request has timed out')
kucher.model.device_model.connection.ConnectionAttemptFailedException: Node info request has timed out
