One of my Orel 20’s ESC’s is stuck in initialization, after attempting to update the firmware. I flashed it via a babel board and uav_gui_tool.
Would a DroneCode probe allow me to kick it and reflash it? Is there a suggestion on how to kick it out of this mode? It was working until I decided to update it from version 1.0 firmware to version 2.0 firmware.
There should be no problem with the embedded UAVCAN bootloader, so in your case there is no difference between the Dronecode Probe and the bootloader. Perhaps that one ESC failed to update because the file transfer was interrupted at some point. Currently it has no valid firmware so it’s just sitting in the bootloader; to fix it, just update its firmware again, and it should go back to normal.
There wasn’t any interruption during the firmware update (This is on my bench using a DC power supply set to 14 volts)… Unfortunately the gui_tool now reports " request timed out when trying to update the firmware again, even after clicking several times in a row.
Can you confirm which binary from Index of /products/io.px4.sapog I should be flashing on my Orel 20’s? Should I be using *.application.bin or *.compound.bin?
Is there a topography to connecting the canbus to the babel board, and powering the board that you recommend?
