Register configuration
“Cyberimplantation is like buying shoes - everyone needs somethin’ different.”
This post will document how to use yakut commands to configure FluxGrip through the Registers interface. This feature is available from firmware version v1.1 and onwards.
Before we start:
- Connect FluxGrip using CANFace
sudo setup_slcan --remove-all -r /dev/serial/by-id/usb-*Zubax*Babel*source ./my_env.shyakut monitor --plug-and-play=pnp.db(leave this one running)
For detailed instruction regarding setup, please see “Preparation” section in the previous post.
Note that after setting the CAN-related registers you’ll need to restart the FluxGrip for the change to take effect.
- call to
uavcan.node.ExecuteCommand- Restart
yakut call <NODE_ID> uavcan.node.ExecuteCommand '{'command': 65535, 'parameter': '1'}' - Factory Reset
yakut call <NODE_ID> uavcan.node.ExecuteCommand '{'command': 65532, 'parameter': '1'}'
- Restart
Registers
write to
uavcan.node.idyakut register-access <NODE_ID> uavcan.node.id <NEW_NODE_ID> # Enable plug-and-play yakut register-access <NODE_ID> uavcan.node.id 65535 -
read/write to
uavcan.node.description# Read yakut register-access <NODE_ID> uavcan.node.description # Write yakut register-access <NODE_ID> uavcan.node.description "New description" -
read/write to
uavcan.can.mtu# Read yakut register-access <NODE_ID> uavcan.can.mtu # Write yakut register-access <NODE_ID> uavcan.can.mtu 8 -
read/write to
uavcan.can.bitrate# Read yakut register-access <NODE_ID> uavcan.can.bitrate # Write yakut register-access 113 uavcan.can.bitrate '1000000 1000000' -
read/write to
uavcan.can.count# Read yakut register-access <NODE_ID> uavcan.can.count # Write yakut register-access <NODE_ID> uavcan.can.count 1 -
read/write to
uavcan.pub.feedback.id# Read yakut register-access <NODE_ID> uavcan.pub.feedback.id # Write yakut register-access <NODE_ID> uavcan.pub.feedback.id 1001 -
read/write to
uavcan.pub.feedback.prio# Read yakut register-access <NODE_ID> uavcan.pub.feedback.prio # Write yakut register-access <NODE_ID> uavcan.pub.feedback.prio 4 -
read/write to
uavcan.sub.command.id# Read yakut register-access <NODE_ID> uavcan.sub.command.id # Write yakut register-access <NODE_ID> uavcan.sub.command.id 1000
