For a plane with vertical take off and landing we need an electric brake on the motors.
Background: When flying as plane (and not as copter) we need to make sure that some
of the foldable propellers do not turn.
Does the current software has an option to activate a brake (to shorten the three phases
of the motor) while the set speed is zero?
This is pretty necessary. Even for normal plane use in some scenarios. Is there an update to the 0.2 beta? Also, anything with a higher watt rating coming out? Either software side or a physical unit?
This is achievable via the direct phase voltage manipulation interface. In Kucher, select “Low-level manipulation”, then “Phase manipulation”. Uncheck the phase synchronization mode checkbox, then move one of the sliders one notch in any direction away from the middle, keeping the other two exactly at the middle. Then click Execute. The motor may jerk once and then it will hold its position until the Low-level manipulation mode is exited.
One should be very careful when dealing with the low-level manipulation mode, because it makes it is easy to destroy the controller, the motor, or the power supply by overloading them.
This brake discussion is very important for many non-multicopter users. Having a “Locking” method like @pavel-kirienko has shown would be great, but any sort of idle braking would be ideal. BLHeli ESC’s have a stop-brake that they implement when the motor is not moving and at 0 throttle. I need something like this as well, otherwise my props dig into the dirt on landing. It doesn’t have to make the motor perfectly still, but the props cannot freely windmill like the current firmware allows at idle throttle.
Is there any way to automate braking at 0-speed after the motor spins down?
With my company we are using your motor controller Myxa for underwater vehicles. The motor position hold feature is pretty important and we would like to integrate it as soon as possible (ideally within the coming weeks). Do you have any idea of the delivery date of this new version, is it aligned with the expectation (2021-Q2)?
If it is any help for you, we could offer to be your beta tester, so you can have a feedback from us using Myxa in a underwater vehicle and we can have this version a little sooner
Hello Pavel, is there any chance this feature has been incorporated into a version of DroneCAN (v0)? We have not made the jump to v1, but motor braking is still desired using the v0 firmware we have set up.
Garrett, we made no attempt to that end. If your application strictly requires this, please shoot us a message to sales@zubax.com, we can work out a deal.
I am using Telega V1 in combination with PX4 and also want to stop the hover propellers of my VTOL during fixed wing flight. Further, I want to park them in a specific position. I do not want to use e.g. a sensor that detects the position and was wondering if I could use Telega’s position estimate to do so. I have noticed that the esc publishes the motor position estimate on the dynamics topic when it gets a velocity setpoint but stops the publishing / restarts the publishing at 0 when there is no vel sp anymore or I switch to servo mode.
Do you know if somebody has done that yet or if the accuracy of the position estimate (after the vertical takeoff) is even sufficient for this use case? Thank you very much for the help
Further, when I was experimenting with the servo mode, I noticed that the ESC stops controlling the position of the motor once I add a force/Nm value to the position SP in the ServoCommand message. This is important for me (at least to my understanding) since the force/Nm value in the ServoCommand determines the current that is applied in servo mode relative to the max motor current . Did i do something wrong?
As a sensorless controller, Telega does not attempt to estimate the actual mechanical angle of the motor. What you see published on the dynamics subject is just the mechanical angle relative to some arbitrary reference angle. This would be exact if the motor had only a single pole pair, as the mechanical angle would equate electrical angle, but if you have an N-pole motor there is an ambiguity as you have N/2 possible reference angles. This problem is unsolvable unless you have some kind of mechanical reference.
The position estimate should be published continuously and in the servo mode the position is controlled continuously, that’s the whole point. The drive may slip if you limit the setpoint too much though.
