Efficient inertial attitude actuator for small spacecraft
Acronyms and abbreviations
- ADACS – attitude determination and control system (spacecraft);
- COTS – commercial off-the-shelf (equipment);
- FEM – finite element modeling (system or structural analysis);
- NRE – non-recurring engineering (costs);
- SRM – switched reluctance machine;
- PMSM – permanent magnet synchronous machine;
- PCB – printed circuit board;
- VSI – voltage source inverter (power electronic circuit);
- UAVCAN – uncomplicated application-level vehicular communication and networking (standard).
Abstract
This is a project status update as of December 2019.
Compared to the original outline, the goals of the project have been amended according to the new information and knowledge we gained during the initial technology evaluation and the initial research of the market. As explained in the document ESA incubation mid-term summary (Jul 2019), the current focus is the development of the weight-efficient and cost-efficient integrated flywheel for CubeSats and other compact space vehicles, with the potential for the future extension towards a complete integrated ADACS.
As of Dec 2019, we have invested over €46k into this project; a detailed breakdown is available in the related financial report. Despite the highly detailed records being available, it is hard to unambiguously segregate the costs of this project from our other activities because this work is closely tied to our core competences and therefore it is entangled with many of our other research activities.
Revised problem statement
As indicated in the linked mid-term summary document, the original plan of applying the existing Telega motor control technology for spacecraft attitude control systems has turned out to be non-viable due to the fundamental mismatch of the constraints and design goals of aerial drives it was originally designed for and those of the new application. The crucial differentiator is the typical load profile: the main objective of an aerospace propulsion drive, or any electric propulsion drive in general, is to overcome adverse forces that impede the movement of the vehicle through space, such as drag, friction, or gravity. The scarcity of the energy reserves available on board dictates that the energy conversion should be done in the most efficient way possible. Therefore, the defining trait of an electric propulsion drive is the ability to deliver high power over long periods of time while minimizing the energy losses. Our motor control solution Telega is designed and carefully optimized to meet those objectives well.
Contrary to that, attitude control systems of spacecraft feature an entirely different load profile: an idealized attitude control system requires no energy input unless the orientation of the spacecraft requires adjustment or the attitude of the spacecraft is adversely affected by an external influence, such as tidal forces from nearby celestial bodies or residual atmospheric drag. Considering the typical operating environment and dynamic properties of spacecraft, the great advances of our technology on the side of energy efficiency lose relevance.
Our improved methods of motor control require high-performance computing hardware and very specific analog circuitry. This results in marginally higher costs of their implementation compared to the industry average. The resulting cost difference and the low relevance of the energy saving advantages render our existing solution suboptimal for use in spacecraft attitude control systems.
According to our engagements with relevant businesses at the Innovation Showcase Summit (it was held at Thales Alenia Space last April) and further market research, manufacturers of space vehicles are interested in a complete integrated ADACS solution as opposed to standalone reaction wheel actuators. The long-term goals of the project shall be formulated accordingly.
The article “Starlink is a very big deal” by Casey Handmer provides highly relevant insights into the influence of the ongoing restructuring of the space launch market on the design of new space vehicles. Particularly, it is shown that the ongoing reduction of the cost of launch per kilogram shifts the focus from high-reliability designs with a long design lifespan towards faster and cheaper iterations. Based on that assessment we predict that in the near future the demand for low-cost standard-compliant inertial attitude control solutions for spacecraft will increase considerably.
The ongoing reduction of the cost of hardware, NRE costs, and acceleration of iterations will drive existing and future manufacturers of space vehicles to favor highly modular, interoperable, and standard-compliant equipment over customized or proprietary developments. We see the nascent of this transition already through our other project which is also tightly related to space flight – the UAVCAN protocol. UAVCAN is an onboard data distribution standard that currently dominates the field of unmanned aerial vehicles while finding new uses in space applications and manned (human-carrying) electric aircraft. Following our prediction, at least two major manufacturers of compact satellites – Spire Global and Open Cosmos – are adopting UAVCAN, thus making the first steps towards an ecosystem of easily reusable UAVCAN-enabled COTS equipment for future space vehicles. Based on the empirical observations made on the market of UAV avionics, and assuming that the trend of UAVCAN adoption growth continues, we expect that in the medium term, future manufacturers of space vehicles will increase their reliance on UAVCAN-compatible COTS equipment. Being equipped with this information and having extensive expertise in the field of real-time safety-critical intra-vehicular communications, Zubax can stay ahead of the curve by equipping the prospective integrated ADACS solution with a UAVCAN-compliant interface.
The electric drive design in question shall be built upon our latest know-how that we developed over the course of our extensive research of electric machines. In particular, at the aforementioned summit at Thales Alenia Space it has been confirmed that the improvement of the mechanical vibration profile achievable with our control methods is of high relevance for space applications. This is because vibrations induced by the attitude control system may adversely affect the operation of certain types of satellite payloads, such as narrow-field-of-view cameras. The following chart shows the vibration amplitude of an electric motor when driven by our motor control solution (blue) and an off-the-shelf competitor (orange).
Upon consideration of the above aspects, we have formulated the following updated set of high-level design objectives for the inertial attitude control solution:
- The drive shall be optimized for continuous operation at high speeds under zero or near-zero load.
- The unit shall be compatible with the 1U CubeSat form-factor standard.
- The mass of the unit shall be minimized to meet the design constraints of CubeSat avionics.
- The complexity and cost of the unit in series production shall be minimized to meet the predicted demands of the future market.
- The prospective ADACS system shall support the UAVCAN standard.
- The drive shall be built upon our know-how in energy-efficient, low-vibration, and robust motor control.
Our approach
At the moment, the R&D is focused on the reaction wheel actuator. Design aspects pertaining to the outer ADACS solution are currently outside of the scope, to be addressed in a later stage of the project.
During the initial study it has been identified that the optimal configuration that meets the high-level objectives is an axial flux motor design where the rotor and the flywheel are implemented in the same element, which is manufactured as a monolithic aluminum body of a specific shape, and the stator is implemented as a set of planar coils on a PCB. Conventional designs based on various types of PMSM are considered suboptimal due to the cost and complexity requirements.
The advantage of the monolithic rotor design is that it allows us to drastically cut costs on manufacturing by virtue of not being dependent on magnetic materials and related sophisticated assembly procedures. Simplified machining enables the manufacturer to achieve far greater balancing of the rotor compared to an equivalent solution that contains permanent magnets. Balancing is of extreme importance for a flywheel drive because it is expected to operate at extremely high speeds in the interest of maximizing the angular momentum storage capability.
Initial FEM analysis performed on topologically-equivalent radial flux motor architectures indicates that both SRM and induction motor architectures are feasible. While SRM are simpler to design, their inherent torque ripple makes them unfit for use in the target application due to the vibration profile requirements. Despite that, we chose to implement both types in the first iteration of the project for purposes of initial assessment of the technology.
An early functional prototype of an axial flux induction drive with a planar PCB stator is shown in the following photo (rotor removed).
The following renders show the current candidate for an SRM-type drive design which is yet to be manufactured. Our progress along this particular path has been greatly hindered by the lack of adequate machining capabilities available in our region – the axial flux SRM design requires the rotor of a complex geometry. In the long term, we intend to equip Zubax with a sufficient manufacturing base to remove our dependency on third-party mechanical manufacturing contractors, as they have proven to be exceptionally troublesome for our work. This is unlike our experience with electronics manufacturing contractors, which are generally highly reliable.
The new design requires a different topology of the VSI and a different control logic compared to the original Telega platform. Ideally, in the case of the induction motor design, we should be able to rely on open-loop feedforward control exclusively – this approach is enabled and made feasible by the fact that the parameters of the driven load (the flywheel) are static and known precisely. The model-based feedforward architecture is expected to simplify the mechanics and electronics, thus improving the adherence to the high-level design goals. The fact that the control system will have to be designed from scratch is not a cause for concern since it will be based on the solid technological base and the know-how developed internally at Zubax prior to this project.
The next steps include completion of the design work, assembly of prototypes, and their detailed evaluation in the lab. We expect that the empirical analysis of the first iteration will be completed by February 2020. This is beyond the original deadline; the delay is explained by the changes to the project structure according to the new information we collected in the process.
Projection
Our evaluation of the current state of the art and available research indicates that this work is novel and has potential for lasting influence on the design of attitude control systems in small spacecraft.
Currently, there is growing interest in leveraging axial flux motors in various applications, including aeronautical systems, due to their improved efficiency and lower disturbances (1, 2). At the same time, the body of research around axial flux electric motors notably lacks coverage of the axial SRM architecture. Our initial FEM analysis indicates that this approach has non-obvious properties that warrant a deeper investigation. Other types of axial motors, particularly PMSM, are used nowadays in a narrow set of applications, particularly electric aviation (often in a stacked configuration for reasons of scalability) and certain types of appliances where their specific shape can be effectively leveraged (e.g., electric lawnmowers).
Considering the ongoing changes in the industry, partially enabled by the advent of low-cost space launch providers, the relevance of our research will increase in the future. In the beginning of 2020, we are situated in an ideal position to introduce a potentially significant change into the future state of the art.
